So I was away from my Macbook Pro for a while and decided to recharge it. After the battery was fully charged, I turned it on, but it is stuck on the loading screen. I have shut it down and turned it back on multiple times to end up with the same results. Can anyone tell me what's going on and if it's possible for me to fix it at home instead of taking it to a Best Buy or Apple store?
