I can't get my iMac to turn on. Occasionally the white apple screen with the spinning icon will come up with the start up sound, but it'll turn right back off. I can't remember which one I have... But according to the bottom, it says
Model: A1419
Hi and Welcome
I would advise you that you either:
1. Restore Your Computer
2. Check the connections
3. Hold down the power button for ten seconds. Then, press the power button again to see if the computer turns on.
4. Reset the SMC
5. Disconnect all accessories that are plugged in to your computer. This includes things like printers, USB hubs, or mobile devices.
