I tunes
Okay I have a older Mac book with an older version of I tunes and I can use the program to listen to music I already have on my mac but I can not access the Itunes store it comes up with (Could not complete the itunes store request. The store may be busy. Check you internet connections or try again later. ) I get this message every time and have checked for updates and tried to upgrade to a newer version but the new one is not compatible with my older 10.4.11 Mac OS X Does anyone know why I am getting this message and how to correct it or how to upgrade my make with out spending a bunch of money it is no longer under warranty and the disk drive doesn't work right so I can't restore it to the original and start over. I am so confused.:confused:
Back
