Struggling to get that deep, punchy bass from your AirPods? There are several simple adjustments you can make to improve your experience, regardless of the music service you use.
Enhancing the bass on your AirPods can transform your music-listening experience. Whether you're adjusting EQ settings in Spotify or Apple Music, choosing the right ear tips for AirPods Pro, or diving into third-party apps for detailed customization, these simple solutions can help you achieve that deep, rich bass sound you're after.
How to Increase Bass on your AirPods
Adjusting Spotify's Equalizer Settings
- Open the Spotify app on your device.
- Tap on "Your Library" in the bottom right corner, then tap on the gear icon in the top right to access "Settings."
- Scroll down and select "Playback."
- Tap on "Equalizer" and ensure it is turned on.
- Choose the "Bass Booster" preset or manually adjust the frequencies. Increasing the sliders around the 60Hz to 150Hz range will enhance the bass.
Using Apple Music's EQ Settings
- Go to "Settings" on your iPhone or iPad.
- Scroll down and tap on "Music."
- Tap on "EQ" under the Playback section.
- Select "Increase Bass" from the list of EQ options.
Choosing the Right Ear Tips for AirPods Pro
- Try the different sizes of ear tips provided with your AirPods Pro.
- Choose the size that offers a snug, comfortable fit, creating a good seal in your ear.
- A good seal helps improve the bass response, making your music sound fuller.
Customizing EQ Through Third-Party Apps
