When WhatsApp keeps reconnecting on your iPhone, it disrupts your messaging and calling experience. Here are several methods to fix this issue.
Disabling Low Power Mode can improve app connectivity, including WhatsApp.
This ensures your Wi-Fi connection doesn't restrict data usage, which can affect WhatsApp.
Allowing more data on your cellular connection can prevent WhatsApp from disconnecting.
Keeping your iOS up to date can improve app performance and connectivity.
1. Check WhatsApp's Server Status
- Visit Downdetector or similar server status checking websites.
- Search for WhatsApp.
- Look for any outage reports.
2. Check Your Internet Connection
- Switch between Wi-Fi and Cellular Data to find the most stable connection.
- For weak cellular coverage, try connecting to a Wi-Fi network.
- For Wi-Fi, ensure your router is working correctly; restart it if necessary.
3. Disable Low Power Mode
- Open the Settings app on your iPhone.
- Scroll down and tap on "Battery".
- Toggle off "Low Power Mode".
4. Disable Low Data Mode for Wi-Fi
- Open Settings.
- Go to "Wi-Fi".
- Tap on the 'i' icon next to your connected network.
- Toggle off "Low Data Mode".
5. Disable Low Data Mode for Cellular
- Open Settings.
- Tap on "Cellular" or "Mobile Data".
- Choose "Mobile Data Options" or "Cellular Data Options".
- Tap "Data Mode" and select "Standard" or "Allow More Data on 5G".
6. Avoid Force Quitting WhatsApp
- Do not frequently swipe up to close WhatsApp from the recent apps.
7. Enable Background App Refresh for WhatsApp
- Go to Settings.
- Scroll down and select "WhatsApp".
- Toggle on "Background App Refresh".
8. Move to the Stable Version of WhatsApp
- If on beta, uninstall WhatsApp.
- Reinstall the stable version from the App Store.
9. Update WhatsApp
- Open the App Store.
- Tap on the Profile icon.
- Scroll to "Available Updates" and update WhatsApp if available.
10. Reinstall WhatsApp
- Remember to back up WhatsApp data to iCloud.
- Uninstall and then reinstall the app from the App Store.
11. Restart Your iPhone
- Use the power off slider to turn off your iPhone, then turn it back on.
- Or, ask Siri to restart your iPhone for newer models.
12. Update iOS to the Latest Stable Version
- Open Settings.
- Go to "General".
- Tap on "Software Update" and update if a new version is available.
13. Reset Network Settings
- Open Settings.
- Navigate to "General".
- Tap "Transfer or Reset iPhone".
- Choose "Reset" and select "Reset Network Settings".
- Enter your passcode and confirm.
Additional Tips
- Check VPN settings. Disable VPN to see if connectivity improves.
- Allow WhatsApp to Use Local Network by going to Settings > WhatsApp > toggle on Local Network.
- Check Cellular Data for WhatsApp: Settings > Cellular > scroll down to find WhatsApp and ensure the switch is enabled.
- Make sure to give WhatsApp permission to send notifications: Settings > Notifications > WhatsApp > Allow Notifications.
