Font problems
PSE 12 Fonts are frozen in Caps. Cannot get anything except caps when typing
I am using a Mac and all my fonts are stuck in Caps. Using Mac OS X Software OS X 10.9.1 (13B42)
I do not have the caps lock on
When I contacted the PSE forum and Digital Scrapper Forum they recommended this might be a MAC problem
I tried resetting preferences and tools etc ~ Did not work
I tried resetting the tool bar
I shut down and restarted the computer
I went into General and went to default all Did not work
This is happening in my PSE 11 on Mac also
I re installed PSE 12 and PSE 11 on my I Mac. Still did not resolve the problem
I saw this problem in the forum on DS and in forum on PSE magazine
one forum said it was due to a freebie download but I tried pages from DS and same problem. It happened after I downloaded a freebie Template from a good site.
I checked for virus and malware on my MAC. ~NONE
The work around is:
Type text in Word or Pages/ Fonts are fine in ALL other programs. Get Caps and lower case letters.
Copy and paste into a transparent file at PSE and then drag to the page you are working on. It creates a vector but you can move the text around and resize it.
You cannot drag out the T tool and paste it in because it goes to all Caps
On my lap top which is a Mac Air I do NOT have the problem.
I am hoping someone can help me.
Thank You
Then it must be a PSE 12 problem, how could it be a Mac problem? PSE does not use the standard input methods and there must be a bug in it. Start by deleting the PSE Preference plists.
The work around is:
Thank You
The work around is:
Thank You
Fixed the problem. Updated PSE files. Then went back in to program and again reset the Text tool and it took. Problem resolved
Back
