Like the MP-600 before it, the Mizuno MX 700 Driver continues Mizuno's departure from the blue color scheme for its woods. While the 600 was black, the MX-700 is a nice charcoal accented by the silver of the alignment decal. Even the Exsar D4 shaft is now black, instead of the line's "any color so long as it's blue" color range of years past. The combination looks nice in an understated sort of way. A gold shaft decal just below the grip adds just a touch of flash.
The Callaway Diablo EDGE Driver is made from Titanium and has been specifically designed to create the perfect smooth hitting feel that will provide you with both maximum driving distance and accuracy off the tee.
Callaway have also managed to reduce the drag on Discount Golf the downswing of the Diablo Driver by up to 8%, using an aerodynamic body design that optimizes all edge transitions. This will give you greater clubhead speed at the moment of impact and consequently more distance off the tee.
Our longest, straightest Callaway FT-iZ Driver has 'barbell-like' weight distribution—58 percent of the mass is in the clubface and 16 percent is in the rear. This produces a high moment of inertia (5,500 g x cm2) and a low CG. In addition, 12 percent of the face area has ball speeds within 2 mph of max speed due to a chemically milled hyperbolic face that optimizes face thickness.
