Connect Macbook Pro to 2 external monitors - Help needed
Hi
I have a Macbook pro 13" late 2011 model.
What I intend to do is connect this to 2 external monitors (if possible).
I am thinking about purchasing 2 of these dell monitors to use with the macbook
http://accessories.euro.dell.com/sna/productdetail.aspx?c=uk&cs=ukdhs1&l=en&s=dh s&sku=732321
What I need help is with, whether it would be possible to connect 2 of these monitors
& what is the best method to use when connecting them (HDMI or VGA?). I do not know alot about this stuff so I would appriciate any help. i.e the adapters that may be needed.
If you have any other suggestions that would also be good.
Thanks
won't drive 2 external monitors.
HDMI, but 1920 x 1080 at 60 Hz is a very low res monitor. So your text and photos may look blurry.
Thanks for the info.
I came accross this and might give it ago:
Also I saw some videos using the dualhead2go but that's pretty expensive.
