Basically about a week ago i downloaded a developer preview of lion and installed. I didn't like it so i downgraded back to leopard using my installation disc then updated to 10.6.8.
However now certain apps wont work. itunes will not work and i get the error shown below (there are also some binary images i haven't posted) and i get a similar error for ical.
And when trying to open certain things in system preferences like 'desktop and screensaver' it stops responding.
Also when trying to use appstore i get this error:
You have Mac*OS*X 10.6.8. The application requires Mac*OS*X 10.7 or later.
I have no doubt this is to do with me downloading the preview and infact some of the apps that come with the preview like facetime still exist in the app folder but with the crossed out circle over them. I have tried deleting and reinstalling apps that dont work but same error exists
Thanks for any help.
itunes error:
Process: iTunes [319]
Path: /Applications/iTunes.app/Contents/MacOS/iTunes
Identifier: com.apple.iTunes
Version: 10.4 (10.4)
Build Info: iTunes-10408001~1
Code Type: X86 (Native)
Parent Process: launchd [197]
Date/Time: 2011-07-27 14:53:30.902 +0100
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 830 sec
Crashes Since Last Report: 3
Per-App Crashes Since Last Report: 1
Anonymous UUID: 8E71A6E7-6A9C-4C06-8DC0-8DA2372CAAC7
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Symbol not found: _kSecOIDX509V1ValidityNotAfter
Referenced from: /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
Expected in: /System/Library/Frameworks/Security.framework/Versions/A/Security
in /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
itunes error:
Report Version: 6
Crashed Thread: 0
Dyld Error Message:
