2011 21.5 INCH IMAC i5 500GB Fans on Constatly
Hi new to the forum and just wanted to see everyone's opinion on my macs fan problem
its the 21.5 inch imac i5 and less than a month old now i didn't notice it when i first powered it up but you can hear the fans whurrring away even with nothing running, i have tried the smc reset but didn't help also tried the pram reset but every time i try it it boots up as if you just bought it asking to use a time machine to restore the os, i did the pram reset on my 2011 macbook pro and beeped restarted and worked fine,
using istat nano i got these fan speed reading
Optical drive 3498rpm
Hard drive 3500rpm
CPU fan 1198rpm
also here are the temps
HD 32
CPU A 35
CPU DIODE 35
CPU HEATSINK 34
AMBIENT 21
MEMORY CONTROLLER 37
OPTICAL DRIVE 32
can anyone have a look at these figures and see if the normal
all help would be very much appreciated
Have you checked Activity Monitor to make sure you don't have a process running?
Back
