No sound from i-dock
I am having trouble with the i-dock for i-pod. When i connect the dock to my stereo via the 3.5mm line on the dock I get no sound. If i connect via the 3.5mm line on the i-pod (the headphone socket) I get perfect sound. Is there anything I need to do or is it likely to be a hardware issue with the dock?
The dock works in all other respects, i.e. it charges and the remote control works perfectly.
Regards
Brad
Hi Brad and welcome,
has it ever worked ?
Or is it new ?
What type of i-Dock is it , there seems to be lots of different products called i-Dock ?
It's is brand new and has not worked during the hour or so I've spent trying to make it work.
I'm not sure of the make, I can check tonight. It is not by apple though.
Hi Brad,
if it's the type I think it is then I would take it back to the shop, and get them to replace with another one...sounds like it's defective.
You should just plug it in and off it goes...
Why does my HomePod sometimes delay sound? 2
Sound not working 3
Sound going 2
NO SOUND 1
Lost all sound output 21
iMac SSD Clicking Sound - Audio Sample 4
Sound Studio 3
Surreal sound 7
