Wacom Intuos3: Skipping mouse pointer + click loss
Discussion in 'Graphics' started by digory, Apr 25, 2008.
  1. digory
    digory Guest
    Hi all
    I have a Wacom Intuos3 A4. The pen works fine, but I'm having problems
    with the mouse. When I let go of it, the mouse pointer does not stand
    exactly still, but keeps skipping from one pixel to the other and
    back. When the mouse is lying on the tablet, the screen saver would
    never be invoked.
    The second problem is that clicks sometimes get lost. I click, nothing
    happens, I click again, now the computer responds. I think the actual
    mouse button is working fine, it seems more to be a problem with the
    driver. However, both problems appear not only when the Wacom is
    plugged to my PowerBook G4 but when I'm using it with my PC as well.
    Has anyone had similar experiences?
    Thanks for your reply.
    Peter
    #1
    1. Advertisements
