Twitter removal...
Discussion in 'Misc' started by CB, Oct 19, 2011.
  1. CB
    CB Guest
    I accidentally clicked on in Safari extensions on the Twitter extension.
    Even though I didn't open an account and deleted every reference I
    saw....it won't go away. Went though preferences and could not find.
    Thanks for any advice.
    CB, Oct 19, 2011
    #1
    1. Advertisements
  2. CB
    Chris Ridd Guest
    Safari > Preferences > Extensions, find the extension, click "Uninstall"?
    Chris Ridd, Oct 19, 2011
    #2
    1. Advertisements
  3. CB
    CB Guest
    Thanks Chris, got it. As usual right in front of me.
    CB, Oct 21, 2011
    #3
    1. Advertisements
