I have the version 2 'Amstrad' Sky Plus box, it originally came with a 20GB hard drive, which gives just under 20 hours of recording...
..between Wifey and the anklebiter, I wasn't getting a look in !
For our American cousins SkyPlus is the same as Tivo (but not as good !)
So I decided to open up the box and take the 20 GB drive out and install a 160 GB drive.
That in theory should give me approx 100-160 hrs, recording time. After having a quick Google around, the consensus of opinion was to put in the Samsung SP1604N. there are various different opinions, but this seemed the best bet.
Local PC World had them in stock (store price £75.98 web price £53.99)
For the techies:
7200rpm Spindle Speed | 2Mb Buffer Cache | 8.9 ms Average Seek Time (Read) | Ultra ATA 133 | Brown box version | No cables, manuals or software included
Before starting go to the "Sky+" Setup Menu and turn instant rewind to off, make sure you scroll down and save the settings, then put the box into standby and unplug it.
Best to leave it to cool down for a few minutes. Make sure you have an Anti Stat Wristband then remove the cover, drive out, and put the new one in...10 minutes.
If you can use a screwdriver, then it's easy ! One ribbon cable - One PSU cable.
Plug in the Sky Plus Box, wait for two minutes, then turn on, go to the Services menu, and access the "Installer Menu..."
Press the Services Menu
Then Select Menu '4' (System Setup)
Then press 01 on the Remote
Then press select
You should now be in the "Installer Menu"
Now press 8 "Full System Reset"
Once this has done it should reboot your SkyPlus Box...wait two minutes then turn it on. Turn your instant rewind back on...and off you go !
Mines been running now for 48 hours, have taped loads of random stuff just to check it's working. Currently have 35 hours taped and the Sky Plus box tells me that there is 65 % still free !!!
Sky Plus home page is here...
Their standard box, the same as mine is £89 with a full package subscription...their new box (with a 160 GB Hard Drive) costs £299 (but only gives 80 hours, there drives are doctored only allowing you to use half the space ???)
If any one wants any advice on upgrading theirs let me know !
Didn't take any pictures at the time, but if I get 5 mins I'll wip the lid off and take some pictures !
For the techies:
Then press select
