Quicktime Pro Question
Discussion in 'Misc' started by Skylamar, Nov 10, 2011.
  1. Skylamar
    Skylamar Guest
    Hi. I have a simple Quicktime Pro (Quicktime 7) question. I own it, but
    I've never really used it.
    I want to make a movie that has a still image and an audio track.
    I opened the PNG file in Quicktime Pro that I wanted to use for the
    still image. Then I dragged the audio file onto that same window. When
    I played the movie, the still image appeared for all of it and the
    audio played fine.
    However, when I exported it as a movie, only the audio file was exported.
    Is there a way to export the movie so the still image will be included too?
    Thanks.
    Sky
    #1
    1. Advertisements
