Quality of the iMac display?
Discussion in 'Graphics' started by Stefan, Feb 1, 2011.
  1. Stefan
    Stefan Guest
    How does the 27" iMac display compare to the 27" Apple Cinema display?
    Are they the same or are there differences? I'm particularly interested
    in color gamut and color accuracy. The monitor will be mostly used for
    Photoshop work.
    (I know, there are better monitors for this task, but that is not the
    question.)
    Stefan, Feb 1, 2011
    #1
    1. Advertisements
