Please Help: Recommend a TV Turner for Mac
Discussion in 'Video Hardware' started by UnixUser, Feb 14, 2011.
  1. UnixUser
    UnixUser Guest
    I am considering purchasing a good/great TV tuner for the Mac, so I can
    watch cable TV on the computer. Can someone please recommend a TV tuner
    that works well with snow leopard 10.6.4? Others on the Internet
    complained that some TV turners often crash on the Mac, while others
    have trouble receiving cable channels via co-axial (not over the air).
    I can use either a PCI or USB slot for the TV turner, so please
    recommend a company and particular model.
    Thanks
    Tony
    #1
    1. Advertisements
  2. The Elgato EyeTV Hybrid works well for me on Mac OX X 10.6.6. It's a
    USB stick connected to my cable service via coax.
    Paul
    Paul Anderson, Feb 14, 2011
    #2
    1. Advertisements
  3. +1. Handles NTSC and ATSC.
    Steve
    steve <at> w0x0f <dot> com
    "Life should not be a journey to the grave with the intention of
    arriving safely in an attractive and well preserved body, but rather to
    skid in sideways, chocolate in one hand, sidecar in the other, body thoroughly
    used up, totally worn out and screaming "WOO HOO what a ride!"
    Steve Fenwick, Feb 15, 2011
    #3
  4. I have older eye tv software that came with a plextor Convertx.
    However, it doesn't seem to work with Dish network. Have any of you
    found a solution that works with satellite tv?
    dick
    James Sidbury, Feb 16, 2011
    #4
    1. Advertisements
