Picture viewer for iMac
Discussion in 'Graphics' started by SchoolTech, Oct 22, 2005.
  1. SchoolTech
    SchoolTech Guest
    I need some simple free software for browsing and viewing pictures on
    an iMac. Something like the functionality of the Windows XP explorer
    thumbnail / filmstrip viewer at a minimum, perhaps with the ability to
    resize photos and simple effects also.
    The system is an earlier iMac (I think it's a 333 CPU) with an older
    version of OS X, possibly Panther.
    #1
    1. Advertisements
  2. SchoolTech
    PAM. Guest
    Is there any way I can make the pictures larger in Konq? I have a few
    hundred I want to sort through and they're a tad small to see what they are
    and drag 'em to the right directory. It would be easier if they were 2-4cm
    in size
    PAM.
    PAM., Oct 24, 2005
    #2
    1. Advertisements
  3. The pictures? ITYM the thumbnails. And, yes, I've often wanted to
    see larger thumbnails in konqueror.
    Jonesy
    Allodoxaphobia, Oct 24, 2005
    #3
  4. SchoolTech
    Shane Guest
    You could use View | Icon Size | Huge
    Making sure View | Preview | Images
    is selected
    HTH
    Shane, Oct 24, 2005
    #4
  5. SchoolTech
    PAM. Guest
    You are correct. I mean thimbnails
    PAM.
    PAM., Oct 24, 2005
    #5
  6. SchoolTech
    PAM. Guest
    Hmmm. I'll check it out.
    Cheers
    PAM.
    PAM., Oct 24, 2005
    #6
  7. Alas. That is what it is currently.
    I'd like to see View | Icon Size | _Custom_
    ...and specify a max pixel width and height.
    Jonesy
    Allodoxaphobia, Oct 25, 2005
    #7
  8. SchoolTech
    Ray Fischer Guest
    Something like iPhoto?
    Ray Fischer, Oct 25, 2005
    #8
  9. SchoolTech
    SchoolTech Guest
    Which version of iPhoto lets you browse a CD?
    SchoolTech, Oct 28, 2005
    #9
  10. SchoolTech
    Calvin Guest
    Calvin, Oct 29, 2005
    #10
  11. SchoolTech
    Dieter Fritz Guest
    Dieter Fritz, Oct 30, 2005
    #11
  12. It will only show a single picture if the window is in column view.
    To get a decent icon view:
    From the Finder open the folder of pictures.
    Go to the View menu, select 'as Icons'.
    Go to the View menu, select 'Show View Options'.
    Make sure 'This window only' is selected, and change the icon size to
    128x128 pixels.
    Roger Johnstone, Invercargill, New Zealand
    http://roger.geek.nz/
    ________________________________________________________________________
    No Silicon Heaven? Preposterous! Where would all the calculators go?
    Kryten, from the Red Dwarf episode "The Last Day"
    Roger Johnstone, Oct 31, 2005
    #12
  13. You have two applications that came with the the OS: Preview and
    iPhoto. If you select all the pictures in the folder and drop them onto
    the Preview icon, thumbnails of all of them will show in the drawer that
    slides out to the side of the window. When you click on a thumbnail,
    its picture will be displayed in the window.
    Preview has some editing functions, too: You can adjust exposure, white
    and black points, gamma, saturation, contrast, sharpness, and sepia
    tone; plus you can crop, flip, and rotate.
    And, of course, you can do more than just that with iPhoto.
    Michelle Steiner, Oct 31, 2005
    #13
    1. Advertisements
