Oversize content in PowerPoint->Keynote slide conversion
Discussion in 'Graphics' started by AES, Jan 23, 2011.
  1. AES
    AES Guest
    When I open a PowerPoint slide show file in Keynote, I often find that
    some of the slide content appears over-sized such that the the last line
    or two of the slide content disappears off the bottom of the slide as
    seen in Keynote.
    Any easy way to fix this?
    AES, Jan 23, 2011
    #1
    1. Advertisements
