OS X application to integrate SIP phone with address book [VoIP,SIP, SIP INVITE]
Discussion in 'Communication' started by seaside, Apr 21, 2004.
  1. seaside
    seaside Guest
    Does someone know of a - probably small application - which allows to
    prepare CALL from within OS X AB to be send to my VoIP phone?
    I suppose, it would send SIP INVITE to my provider. Then the near and
    the far side should ring.
    If it does not integrate with AB, but is useable as an external application,
    would be fine as well.
    Stefan
    #1
    1. Advertisements
