Microsoft Remote Desktop vs 2 - shift key weirdness
Discussion in 'UK Macs' started by jim, Jul 24, 2008.
  1. jim
    jim Guest
    Anyone else using RDC v 2 ? If so, do you find that it doesn't reliably
    send shift-key status?
    Trying to type "A$" quite often results in "A4".
    Reverted to v1.0.3 and so far so good.
    Jim
    jim, Jul 24, 2008
    #1
    1. Advertisements
  2. jim
    jim Guest
    The only odd thing I was doing was RDC'ing to the work server, then
    RDC'ing from it to another machine. I wonder if v2 doesn't cope well in
    'nested' RDC environments.
    Using v1 seems fine.
    Jim
    jim, Jul 24, 2008
    #2
    1. Advertisements
  3. I've had that, no shift key affect at all. Went back to VNC.
    Cheers - Jaimie
    Jaimie Vandenbergh, Jul 24, 2008
    #3
  4. jim
    jim Guest
    FWIW this was RDC'ing to a Windows 2000 server, then from it to an XP
    box.
    I haven't tested whether the shift-key oddity was there if I was only on
    the W2K machine.
    Jim
    jim, Jul 24, 2008
    #4
  5. That reminds me that I've had the same problem using Apple's Screen
    Sharing (ie VNC) to a Mac in order to poke an XP running in Parallels.
    Shift state wasn't transferred to the XP vm.
    Totally different route, same result. Curious.
    Cheers - Jaimie
    #5
  6. jim
    jim Guest
    Fixed it. It wasn't affecting a connection just to the W2K machine, so
    it was something to do with the hop from there to the XP machine.
    On the W2K machine I changed RDC's Options->Local Resources->Keyboard to
    'On the local computer'
    This _seems_ to have fixed it.
    So not actually a Mac problem after all, but might be useful to someone.
    Jim
    jim, Jul 24, 2008
    #6
  7. jim
    Jon B Guest
    I could never replicate it in an excel sheet, but I reliably couldn't
    get the case sensitive password right in our BACS banking software using
    the v2 beta, and guessed as it worked fine in v1.x something wasn't
    right in v2, I reverted back too.
    I'd not tried this release, probably for the best.
    Jon B, Jul 24, 2008
    #7
  8. jim
    Rob Guest
    Works perfectly fine in a sluggish sort of way with work's Windows 2003
    server, and an iMac/Leopard.
    Rob
    Rob, Jul 24, 2008
    #8
  9. jim
    jim Guest
    Yes, the problem turned out to be with the RDC client on the W2K machine
    - looks like it wasn't consistently passing on modifier values until a
    setting was tweaked.
    Jim
    jim, Jul 24, 2008
    #9
  10. jim
    Jon B Guest
    Which setting was that, be useful to tweak ours.
    Jon B, Jul 24, 2008
    #10
  11. jim
    jim Guest
    Jim
    jim, Jul 24, 2008
    #11
  12. jim
    Jon B Guest
    Thanks will look into that later.
    Jon B, Jul 24, 2008
    #12
  13. jim
    Nick Bell Guest
    I sometimes find that CAPS LOCK status is completely reversed, i.e. if
    CL on, all lower case, and vv.
    Nick
    Nick Bell, Jul 25, 2008
    #13
  14. jim
    shadowwraith New Member
    Oct 9, 2017
    I actually do something even wierder...I login to a mac from a mac. The mac I am logging into has configured Microsoft Remote Desktop to connect to a PC.
    I too was having this problem where the shift key was not working. I don't know but it may be that the response of the system is too slow or "breaks" the continuity of simultaneously holding the shift key down and pressing a key.
    What I did was hit the shift key 5 times in succession activating "Sticky Keys" (you may get a dialog the first time you do this). So now I am able to enter the shift+2 to get @ or shift+4 to get $.
    There maybe some control panel on the client you are connecting to that will allow it to wait longer for key repeats or something along those lines, but I haven't messed with this.
    Good luck.
    p.s.
    For awhile a work around I did was to setup Teamviewer. That works without all the shift key shenaniggans.
    shadowwraith, Oct 9, 2017
    #14
    1. Advertisements
