ksh scripting problem
Discussion in 'Programmer Misc' started by Robert Peirce, Feb 8, 2008.
  1. Does anybody have any idea why this works:
    IFS=' '
    exec 0< "db/s.d"
    while read line
    do
    set $line
    if (($3>0)) && ((${15}<16))
    then
    And this doesn't?
    exec 0< "s.p"
    while read line
    do
    set $line
    ((++wkcnt))
    if (($1>0)) [>0: arithmetic syntax error]
    then
    The line is getting read correctly as shown if I do a print $1 after the
    set.
    Actually, since the line in the second case only holds one field,
    it should be possible to get away without doing a set, but I was trying
    to match the other code.
    The first few lines of s.p look like
    16.1299990
    16.7199990
    16.9800000
    16.0000000
    16.9900000
    #1
    1. Advertisements
  2. Abject apologies for rank stupidity. Each line in the s.p file ends
    with \r\n instead of just \n. It is necessary to replace "set $line"
    with something like p=$(print $line | tr -d '\r'). Then ((p>0)) works
    fine.
    The \r crap is a holdover from Windows.
    #2
    1. Advertisements
  3. Okay. Here's a real puzzle and I don't think it has anything to do with
    \r.
    This doesn't work. It hangs at the if statement, which doesn't execute.
    p=$(echo $line | tr -d '\r')
    ((++wkcnt))
    if ((p>0))
    This does work
    ((++wkcnt))
    if ((p>0))
    As does this
    ((++wkcnt))
    if ((p>0))
    You need something after ((++wkcnt)) for if to work and that makes no
    sense to me at all.
    #3
  4. I was advised to use the ksh built-in read line to read in a really huge
    file. Well, it turns out, probably because ksh is an interpreter, that
    read line, at least as demonstrated by the following script
    #!/bin/ksh
    exec 0< "db/s.p"
    while read line
    do
    print $line >> /dev/null [echo is actually a hair faster]
    done
    takes way, way longer than cat db/s.p. Consequently, unless someone can
    give me a very fast way to use read line, I am going to stick with my
    kludge of splitting s.p into 50,000 line pieces and processing them in
    order.
    #4
    1. Advertisements
