Hi, I have not been able to use iPhoto since I updated to Leopard. Mac Support tells me there (may) be an update to fix this but I've seen nothing. Has anyone else had this problem? iPhoto quits as soon as I open it.
Yes, from what I've been told by Mac Support it is. It's version 2.0.1
I have no problem with iPhoto on my new MacBook (Intel) but it quits automatically upon opening on my G4. Any clues? Thanks.
Interesting. After doing some brief research, iPhoto 2.0.1 seems to be broken in many Leopard installation cases. Even if iPhoto may technically be compatible, as the Apple employee suggested, it seems that in actuality, that is not the case in most of these scenarios. You may have to upgrade iLife; but I will continue to look around for a solution and edit my post if I find one for you.
