I had the Adobe CS3 Design premium working perfectly until one day Illustrator wouldnt start anymore.
While launching and searching for the plugins the application crashes and stops working. The pluging in question is the PDF-suite.aip.
I have reinstalled and tryed to find out that same plugin either n the lybrary aswell as in the web but without any sucess.
I also suspect it has something to do with the MacOsx software updates.
Is there anyone you can help me.
thank you for your time.
Manel
Manel
