iLIfe '09 / iWork '09 -- An Odd Difference
Discussion in 'Video Hardware' started by TaliesinSoft, Aug 28, 2010.
  1. TaliesinSoft
    TaliesinSoft Guest
    When one installs iLife '09 the member applications, GarageBand, iDVD,
    iMovie, iPhoto, and iWeb are installed directly into the Applications
    folder, but when one installs iWork '09 the member applictions,
    Keynote, Numbers, and Pages are installed in a containing folder titled
    "iWork '09".
    This came to my attention yesterday as I attempted to download the
    update to Pages which includes the ability to export a document in the
    ePub format. It seems that a few months ago I moved the three iWork '09
    applications out of the containing folder, an action that had no
    adverse effect until yesterday as the updater was looking for that
    folder. Restoring the folder and moving the applications into it did
    the job and the updater worked fine.
    So I'm curious as to why Apple chose to have this packaging
    inconsistancy for these two application suites.
    James Leo Ryan - Austin, Texas
    #1
    1. Advertisements
  2. TaliesinSoft
    TaliesinSoft Guest
    On 2010-08-28 09:05:11 -0500, TaliesinSoft said:
    [as I inadvertently posted to a multiplicity of newsgroups]
    My bad, my bad, my bad....
    my opening posting in this thread was meant to go only to
    comp.sys.mac.apps, but I somehow overlooked that it was being
    crossposted. I've suggested to Panic that they include a crossposting
    warning in Unison, the newsreader I'm using, that would bonk idiots
    like me on the head!
    #2
    1. Advertisements
  3. TaliesinSoft <> writes:
    > titled "iWork '09".
    > '09 applications out of the containing folder, an action that had no
    I'm mildy curious too.
    I'll note that it mimics the behavior of MS Office on macs - that too
    installs as one folder with the separate applications contained in
    that folder.
    Doug Anderson, Aug 28, 2010
    #3
    1. Advertisements
  1. TaliesinSoft
    60
    653
    Wes Groleau
    Aug 31, 2010
  2. TaliesinSoft
    TaliesinSoft, Aug 28, 2010, in forum: Databases
    555
    Doug Anderson
    Aug 28, 2010
  3. TaliesinSoft
    TaliesinSoft, Aug 28, 2010, in forum: Communication
    305
    Doug Anderson
    Aug 28, 2010
  4. TaliesinSoft
    TaliesinSoft, Aug 28, 2010, in forum: Graphics
    581
    Doug Anderson
    Aug 28, 2010
  5. TaliesinSoft
    TaliesinSoft, Aug 28, 2010, in forum: Hardware
    239
    Doug Anderson
    Aug 28, 2010
  6. TaliesinSoft
    TaliesinSoft, Aug 28, 2010, in forum: Storage
    411
    Doug Anderson
    Aug 28, 2010
  7. TaliesinSoft
    11
    355
    Rich Gray
    Sep 12, 2010
  8. TaliesinSoft
    TaliesinSoft, Aug 28, 2010, in forum: Portables
    530
    Doug Anderson
    Aug 28, 2010
Loading...
