How do I press CTRL-ALT-DEL on a Mac ?
Discussion in 'UK Macs' started by Pete French, Jan 13, 2004.
  1. Pete French
    Pete French Guest
    So, I dont appear to have a delete key on the keyboard - only a backspace
    key top right. I can generate a delete character using ctrl-? I
    guess, but I need to be able to type CTRL-ALT-DEL in order to logon
    to a windows 2000 box that i am accessing remotely. Any ideas ?
    The setup is that there is X11 running on the Mac, then I am using ssh
    to connect to a UNIX machine at work with '-X' turned on to
    tunnel X. On the UNIX machine I am running vncviewer to connect to
    the windows machine. I do this all the time from other UNIX
    machines, but never from the Mac before.
    Not getting very far as I cant login to the Windows machine :-(
    -bat.
    #1
    1. Advertisements
  2. Pete French
    Chris Ridd Guest
    I don't know about Ctrl-Alt-Del, but to get a right-delete hold down Fn and
    hit the Backspace.
    I've used Chicken of the VNC (a VNC client) on Panther, and IIRC it has a
    menu item that sends a Ctrl-Alt-Del to the Windows box.
    You should also consider using Remote Desktop Connection instead of to talk
    to the Windows box.
    <http://www.microsoft.com/mac/otherproducts/otherproducts.aspx?pid=remotedes
    ktopclient>
    You can easily tunnel RDP connections using ssh, if you need to. (It uses
    port 3689.)
    Cheers,
    Chris
    Chris Ridd, Jan 13, 2004
    #2
    Ray94903 likes this.
    1. Advertisements
  3. Pete French
    Ian Piper Guest
    ISTR that in Virtual PC it is cmd-opt-shift-backspace.
    Ian Piper, Jan 13, 2004
    #3
  4. Pete French
    David Glover Guest
    I presume you are on a portable.
    Delete is Fn-Backspace, and so the keypress you are looking for is
    Fn-Ctrl-Command-Backspace
    David Glover, Jan 13, 2004
    #4
  5. Pete French
    SteveH Guest
    That works using Microsoft Remote Desktop to access the WinXP box in the
    spare room, IYSWIM.
    I've been wondering how to do that for _ages_.
    Nice one.
    SteveH, Jan 13, 2004
    #5
  6. So have I (ever since I first got a mac nearly two years ago). We live
    and learn.
    Stuart Hutchinson, Jan 14, 2004
    #6
  7. Pete French
    Chris Ridd Guest
    I'm not sure how or where I discovered it. Backspace isn't in the list of
    keys that get modified when you use Fn in any of the Apple docs I just
    checked. Ah well, it works, and is useful :)
    Cheers,
    Chris
    Chris Ridd, Jan 14, 2004
    #7
  8. Pete French
    Ray94903 New Member
    Mar 14, 2018
    The equivalent of CTRL-ALT-DEL on a Mac is Control + (Fn+Option) + Delete
    Ray
    Ray94903, Mar 15, 2018
    #8
    1. Advertisements
