Hi all
I have tried to make automator do one thing for me, and it works as long as its a workflow but i need to have it as an app that can be started/run every time i log in and keep running in the background.
I want aotomator to serach for torrent files in my Download folder, IF found move them to a folder located on my NAS and then open the file with a torrent client. But it seems like if no torrent files are found when a log into my computer (So the app is starting as i wanted) i get an error "Error wile moving file".
How can i best do to make automator app search for files and if nothing is found it goes to a halt and just waits (search continuously ) and moves files when the appear ?
Below is how i did it, but maybe a IF loop or something is needed if no files found ?
Its in Swedish i am afraid but maybe you can have an idea anyway.
Br
Patrik
Br
Patrik
