help compiling..
Im very new to using the terminal however im a long time mac user. i am trying to compile programs, however, i cannot seem to do this. I have xcode installed. I am trying to compile ettercap 0.6.7 and it will ./configure, but when i 'make' it says:
/usr/bin/ld: Undefined symbols:
_GETLONG
_GETSHORT
_PUTSHORT
collect2: ld returned 1 exit status
make: *** [ettercap] Error 1
Also, can someone elp me compile yawcu (http://sourceforge.net/projects/yawcu)? there is no file or directory when i try to 'configure.' these questions may be easy to fix, i dont know hardly anything about unix. thanks
Hi there and welcome !
What version of OS X have you got ?
And what version of Xcode ?
I would also have a look at using Fink or Darwin ports, this may make your life a little easier.
I currently have Fink running, have a read through the documentation on their pages and let me know which way you want to go !
You would probably be better running Ethereal...
Have you looked at Kismac ?
Hi there,
I will give you a tutorial later tonight !
Your options are a little limited at the minute whilst all the good software, is converted to the Intel chip...
...haven't forgotten just trying to find the time.
I'll get round to it by the weekend...
I also tried to compile ettercap using the same version. My version of OS X and XCode are the same as treethousand. Do you know what that error message means? Does it have anything to do with the gcc compiler? My parents have a router with no password and I want to make sure that no one is logging into the router. I have been researching for a long time and I cannot get ettercap to work.
Also if I was going to use KisMac would I need to get a different network card? Because I tried to use it with airport card, passive but it threw an error?
-Thanks Matt
