Exec() & System() not Working?
Discussion in 'Programmer Misc' started by VikR, Nov 10, 2010.
  1. VikR
    VikR Guest
    When executed from the terminal, the following command works
    gnuplot '/Applications/IPG/htdocs/ftp/company_name/Charts/
    However, when I run it from inside PHP with:
    exec("gnuplot '/Applications/IPG/htdocs/ftp/company_name/Charts/
    system("gnuplot '/Applications/IPG/htdocs/ftp/company_name/Charts/
    ....nothing seems to happen. How can I correct this?
    Note - exec is enabled on my system, according to the following
    function exec_enabled() {
    $disabled = explode(', ', ini_get('disable_functions'));
    return !in_array('exec', $disabled);
    Thanks very much in advance to all for any info.
    VikR, Nov 10, 2010
    1. Advertisements
  2. VikR
    VikR Guest
    Thanks very much for your help. It's working now. Code currently being
    $shellCommmand = "/usr/local/bin/gnuplot '" . $pathToCommandFile .
    $output = system($shellCommmand . " 2>&1");
    VikR, Nov 10, 2010
    1. Advertisements
