Just need some help. I have a clamshell iBook and just upgraded the Hardrive in it. Went from a 3GB to a 30GB. I was running 9.2OS on the 3GB and the new one I put in was blank no OS on it yet. So after putting it all back together I went to boot everything sounds like its running. But here is the problem the screen goes blank on start up (boot) After I push the on button its a black screen some times I will get a 1 or 2 second flash of gray (full screen) then it goes back to a black or off screen. So I took it all apart and put the old 3GB back in to see if that would get the screen to work and same thing. Please let me know what you think might had happened as it worked just fine before I started messing around with it.
Thanks so much !
Brandon
Thanks so much !
Brandon
