Capturing w/Videovision PCI Powermac 9600 Newertech G4 400
Discussion in 'Video Hardware' started by Thor Stevens, Sep 19, 2009.
  1. Thor Stevens
    Thor Stevens Guest
    Wanted to capture some analog footage so I got my 9600/G4 400 out of
    storage and started on Mac 9.2.1
    The radius codec I used to capture (VVPCI 1.3) played back Green and
    pink artifacts. If I captured to another codec it was fine.
    I then downgraded to 9.04 with the same issue and went back as far as
    I even tried VVPCI 1.0
    My Videovision card is in the bottom slot of the 9600.
    Has anyone else had this problem?
    Should I put the card in another slot?
    Should I try to find a 9600/350 daughtercard processor?
    Should I try to reseat the Radius card?
    Is there a VVPCI 1.2 ?
    Since this video footage is eventually going to DVD, should I just
    capture to Mpeg 2 ?
    I don't have the funds for a Canopus ADVC55 or 110 which would capture
    just fine.
    Any help would be welcome
    1. Advertisements
