I have recently bought a 24" 2.4GHz iMac with Mac OS 10.5.1 installed on it.
I have tried using Automators "watch me do" and i wanted to repeat my workflow a few times.
When I add the "Loop" to the workflow, it runs through the loop twice and then stops. Automator says that it is still looping. It doesn't matter if I run the loop for a certain time period or a certain number of executions; it always hangs after the second loop.
This also happens when i use the "run workflow" action, but it repeats 3 times and then does the same thing.
Any Help would be appreciated....
Thanks
Thanks
