Any suggestions for SDI card for G5 or Mac Pro?
Discussion in 'Video Hardware' started by Kit, Nov 17, 2008.
  1. Kit
    Kit Guest
    I have recently bought a Panasonic AJ-SDX900P with the optional SDI
    board installed. This camcorder records 525-line NTSC at 60i onto
    DVCPRO tapes. It can also record 24p and 30p (both captured over 60i)
    with 4:2:2 colour compression.
    I am a very light user and prefer not to buy a deck but instead
    play-out the tapes direct from camcorder and record into my Mac.
    However, my Mac has no SDI input port. So I would be very grateful to
    receive suggestions of which card, board or box might suit me best.
    Currently, my Mac is a G5 Dual 2.5GHz. I plan to get a Mac Pro sooner
    or later (but I shall keep the G5 Dual) so if there is an especially
    attractive Intel-based solution then I might buy the Mac Pro sooner.
    Thank you!
    Kit, Nov 17, 2008
    1. Advertisements
