what progams (i.e. menu extras) are running in backround?
Discussion in 'Apps' started by Frank, Oct 28, 2003.
  1. Frank
    Frank Guest
    is there any way to check what extras are running such as menu extras,
    drop down extras, etc? i think one of them is incompatable with
    panther causing it to quit apps as they start.
    -frank
    Frank, Oct 28, 2003
    #1
    1. Advertisements
    Process Viewer in your Applications/Utilities folder. But you'll find
    lots of things running, and a lot of them should be running.
    | ^Nothing is foolproof to a sufficiently talented fool^ |
    | Heath Raftery, HRSoftWorks _\|/_ |
    *______________________________________m_('.')_m_________*
    Heath Raftery, Oct 28, 2003
    #2
    1. Advertisements
  3. Frank
    David Dunham Guest
    In article <>, Frank
    You could also generate a System Profiler report and look for
    Extensions.
    I know ASM and Default Folder both need to be updated for Panther (that
    is, you need to download the latest version -- the developer has
    updated them).
    David Dunham A Sharp david@SPAM_B_GONE.a-sharp.com
    http://www.pensee.com/dunham/
    "I say we should listen to the customers and give them what they want."
    "What they want is better products for free." --Scott Adams
    David Dunham, Oct 31, 2003
    #3
    1. Advertisements
It takes just 2 minutes to sign up (and it's free!). Just click the sign up button to choose a username and then you can ask your own questions on the forum.
  1. Nelson
    138
  2. Florian Zschocke
    232
    Florian Zschocke
    Jun 7, 2006
  3. Paul Meier
    flash widget with trancparent backround
    Paul Meier, Jun 26, 2006, in forum: Programmer Help
    200
    Paul Meier
    Jun 26, 2006
  4. mhz
    510
  5. Jo_y
    why mac os have white backround layouts???
    Jo_y, Oct 27, 2009, in forum: Programmer Misc
    434
  6. Frank
    220
    Kevin A. Scaldeferri
    Nov 6, 2003
  7. Michelle Steiner
    Menu Extras
    Michelle Steiner, Dec 14, 2004, in forum: Mac
    198
    Michelle Steiner
    Dec 14, 2004
  8. OtavioCC
    402
Loading...
