Hi there,
I understood what you want yura, but I really think that isn't possible. You must be select the photos again and separate each one of them.
You can try press the keys Command + A on tab Photos, and then remove the pictures that you already transfered to external drive, so the next steps is FIle > Export and select the correct way.
I really don't know another different step.
Jim,
