Replacement for Palm Desktop?
Discussion in 'Apps' started by Nick Naym, Sep 25, 2010.
  1. Nick Naym
    Nick Naym Guest
    It does everything I need and want: A desktop app that integrates contacts,
    memos, calendar, and to-dos, and provides significant flexibility within and
    among each of those modules. (Yeah, it includes the ability to sync with a
    Palm handheld...but I never used it, and don't care about it: I never had a
    need for a handheld.)
    It still works with SL...but increasingly (with each SL update) it's
    becoming a bit unstable. I'd hate to boot up one day and find the past 20
    years of PIM info stuck in an app that can no longer be opened.
    iMac (27", 3.06 GHz Intel Core 2 Duo, 4 GB RAM, 1 TB HDD) € OS X (10.6.3)
    #1
    1. Advertisements
  2. Nick Naym
    Király Guest
    If you don't need to sync with a handheld, Apple's built-in Address
    Book, iCal, and Mail can do all of those things, and they are well
    integrated with each other.
    K.
    Lang may your lum reek.
    Király, Sep 25, 2010
    #2
    1. Advertisements
  3. Nick Naym
    Nick Naym Guest
    In article Wnsno.1167$89.540@edtnps83, Király at wrote
    on 9/25/10 3:50 PM:
    Have you ever used Palm Desktop?
    When I first moved to OS X from (believe it or not) OS 9, (2008), I looked
    forward to using iCal, Address Book, and -- though I didn't quite see how --
    Mail as a replacement to Palm Desktop. I never got beyond playing with iCal
    and Address book: They simply didn't hold a candle to Palm. Palm's
    "flexibility" in something as simple as setting appointment alarms/reminders
    left iCal at the starting gate. And Memos? There is no analogous function in
    iCal/Address Book. I was willing to forgo that feature if I had to...but as
    I began to migrate away from Palm Desktop, I felt like I was taking a
    significant step down in feature functionality -- analogous to migrating
    from a reasonably full-featured word processing program to something like
    SimpleText. I finally gave up.
    If you've never used Palm Desktop, you can still download and install it
    (though the sync function doesn't work and, in my experience, it's not quite
    as stable/smooth as it was under Leopard). The last version was Palm Desktop
    4.2.1 Rev A, and it's here:
    http://qgf.in/KiyG3E
    If you can install it and play with it for a few hours, maybe you'll see
    what I mean. (Now, if you _have_ used the program, and believe that Apple's
    trio of apps is an on-par replacement, then I must be doing things
    drastically wrong, and I'd very much appreciate some help!)
    #3
  4. Nick Naym
    Király Guest
    Oh yes I have. I tried it out for a few days when I bought my Palm Zire
    in 2004, but quickly ditched it for iSync conduit so that I could use
    the Apple software.
    I had the opposite experience. Apple's apps could hold so much more
    information than the Palm. They had fields that wouldn't even sync with
    my Palm device.
    > Palm's "flexibility" in something as simple as setting appointment
    > alarms/reminders left iCal at the starting gate.
    Opposite experience again. iCal's interface just seemed to make more
    sense to me, and so it was very easy to learn. Mind you, I never tried
    setting up an alarm in Palm Desktop, because I ended up ditching it
    before the need arose.
    > And Memos? There is no analogous function in iCal/Address Book.
    Correct, but you were looking in the wrong place. It's in Mail.
    Different strokes, I guess. I couldn't find one thing that Palm Desktop
    could do that the Apple apps couldn't do just as well, if not better.
    Nooooooo, thanks. Been there, done that, couldn't stand it, TYVM.
    It has been a long time since I used Palm Desktop so I won't be of much
    help providing a step-by-step conversion process. But if you can
    explain exactly what you want to do, many of us I'm sure will be glad to
    help.
    K.
    Király, Sep 26, 2010
    #4
    >>> Palm handheld...but I never used it, and don't care about it: I neverhad a
    You can export all the data as 'Tab and Return' plain text, so it should
    be possible to import these .txt files into any application that support
    this format...
    I'm also one of those who still use PalmDesktop (without a handheld),
    and it's still the app I like most when I need a date&time + memo
    application, - though it's not as much anymore as it has been now that
    I've retired from business world.
    I run it on all my machines including my Windows XPPro setup both on
    PowerPC and an Intel MacPro, and it's just working perfect, no errors,
    no bugs - as far as I'm aware of, - simply just running. I use both
    10.4.x and 10.5.x as well on all my Macs - also because I still need
    either classic mode or direct OS 9.2.x boot up. this of course is
    running on a MDD PowerPC...
    My version is ver. 4.1.x for both OS 9.x and OS X. I tried the 4.2.1,
    but found it somewhat more unstable than the older 4.1.x. I think you
    can install the ver. 4.2.1 through the installer even on OS X 10.6, but
    whether it will be stable or unstable I don't (yet) know, since I'm
    still on 10.5.8 on the MacPro. I could easily install it even on 10.5,
    so I just ran the installer and then copied the prefs files from the old
    Tiger disk so all settings are the same on all machines. This works very
    fine here.
    As far as I'm aware of there are no real substitutions for PalmDesktop
    calendar & notes software - ...unfortunately.:-(
    As for migrating I tried a quick Google search and a.m.o. found this
    http://discussions.apple.com/thread.jspa?messageID=11211970
    Cheers, Erik Richard
    Erik Richard Sørensen, Member of ADC, <>
    NisusWriter - The Future In Multilingual Text Processing - www.nisus.com
    OpenOffice.org - The Modern Productivity Solution - www.openoffice.org
    Erik Richard Sørensen, Sep 26, 2010
    #5
  6. Nick Naym
    Nick Naym Guest
    In article tph-64C911.17070125092010@localhost, Tom Harrington at
    wrote on 9/25/10 7:07 PM:
    > In article <C8C2B571.64FBD%nicknaym@_remove_this_gmail.com.invalid>,
    > Two possible alternatives include SOHO Organizer
    > (http://www.chronosnet.com/Products/sohoorganizer.html) and Daylite
    > (http://www.marketcircle.com/daylite/).
    I began to try SOHO last March, but immediately ran into problems trying to
    move my Palm data. There's been a minor update in the app since then, but I
    doubt that it makes any difference to the underlying issue (data format)
    that seemed to be the core of the problem.
    I'm not familiar with Daylite. I'll see what I can find out.
    Nick Naym, Sep 26, 2010
    #6
  7. In article <CJvno.998$u9.19@edtnps82>, (Király)
    > the Apple software.
    > my Palm device.
    > help.
    There is an app that is available from www.markspace.com - I used it
    both with a Palm Pilot and a Blackberry phone. It seemed to work
    relatively well, and the synch process was (I thought) livable.
    Have you tried it? Or maybe it has gone the way of the Blue Chip GM
    Stocks by now? (I have been an iPhoner for over two years now so I am
    not aware of what happened to then, as I no longer need the app...)
    Good luck.
    S.
    Sebastian Tombs, Sep 26, 2010
    #7
  8. Nick Naym
    105 Guest
    well integrated maybe; but not in some of the really useful ways Palm
    Desktop is/was; date/time stamping in notes, auto-attachment based on
    name typing...
    PD was well thought out, Apple could take a few lessons from it.
    Tom, I also had been using PD since the early days; but gave up during
    Tiger. Kept going back to have another look (last revisit a few months
    ago), but felt stability was progressively an issue. Similarly, never
    had an actual Palm.
    Chris
    105, Oct 4, 2010
    #8
  9. Nick Naym
    Jim Gibson Guest
    In article <4caa4499$0$28649$>, 105
    > name typing...
    Ironic, because the first Mac-only version of Palm Desktop was
    purchased by 3COM from Apple as Claris Organizer and renamed Palm
    Desktop 2.
    <http://en.wikipedia.org/wiki/Palm_Desktop>
    Jim Gibson
    Jim Gibson, Oct 5, 2010
    #9
    1. Advertisements
It takes just 2 minutes to sign up (and it's free!). Just click the sign up button to choose a username and then you can ask your own questions on the forum.
  1. Newsbot
    525
    Newsbot
    Dec 19, 2007
  2. Mkkov1
    Palm Desktop problem
    Mkkov1, Jan 28, 2008, in forum: Mac Applications
    393
    Mkkov1
    Jan 28, 2008
  3. Robert Peirce
    Palm Desktop 4.1 for Mac and Memos
    Robert Peirce, Aug 14, 2003, in forum: Apps
    87
    Robert Peirce
    Aug 15, 2003
  4. Andrew Starr
    134
    James Meiss
    Sep 12, 2003
  5. Rowbotth
    160
    David Empson
    Mar 26, 2007
  6. Mirsky
    324
    Mirsky
    Sep 4, 2007
  7. hee_hee
    170
    Wes Groleau
    Oct 31, 2006
  8. Brian Millson
    Palm Zire Replacement
    Brian Millson, Jul 12, 2006, in forum: UK Macs
    42
    453
    Mr B;
    Jul 18, 2006
Loading...
