help with mac please
When looking at the mac there is a button with 3 squares, the top key 4 to right of esc. When i press that i have about 10 powerpoint slides up and I don't know how to delete them.. please help me
You cannot delete them, they are your open applications.
To get rid of them you simply need to quit the apps that are open by using the command: Command+q or Command+Option+Esc
Good luck
