basically, as the image shows, when i enter the pinyin, the character suggestions are not showing up, this happened completely out of the blue and I have no idea how to fix this problem. Usually they drop down under where the pinyin is being typed and I can select an option. I'm currently studying chinese so this is a huge problem for me. can any of you guys help?
Thanks!!!
Thanks!!!
