Can anyone with Magic Garageband help me please?
I recently killed my beloved Macbook and sadly lost all my files. Sad times.
So I had a track, constructed from the Magic garageband BLUES track - it's being used in a show and was perfect - but my replacement computer has a new garageband (10.1.2) and it's proving really difficult to install the older version (4/5/6). I did try to make the song from scratch but am failing and the loops on the updated version are not sufficient to make it. It would be so easy to make it again if I had access to the demo BLUES track but nobody I know has an old version of the app.
Does anyone out there still use Garageband 4/5/6? Would anyone be able to dropbox me the file? It should only take a few minutes - It's literally the demo they give with a couple of instruments changed.
So frustrating!
Please do get in touch if you can help.
Thanks.
I have GarageBand 6 I'd be happy to help but need you to tell me exactly what & where as I use Logic Pro 9 mostly these days.
